Tom's Hardware > Forum > Home Theatre > ReplayTV > Problem with Showstopper PV-HS2000
Forum Home Theatre : ReplayTV - Problem with Showstopper PV-HS2000
Archived from groups: alt.video.ptv.replaytv (More info?)
My Panasonic Showstopper PV-HS2000 displays "Please Wait a Few Moments ...."
screen when turn on but it doesn't do anything after that, I can't use
remote or even turn it off with the power button. Is it bad sign? this
unit works before .......
Thanks
Sponsored Links
>Thanks
These units will often reboot themselves with no warning if there's an
error. It's likely to be a damaged disk.
55 days until the winter solstice celebration
Mark Lloyd
http://notstupid.laughingsquid.com
Reply to Anonymous
- 0 +
Thanks for your inputs.
Your signature remind me of the guy I used to know, he also knows alot about
replaytv too. Matter of fact I like him a lot so that I name my email after
him. Hope you know him too.
Thanks Noone
"Mark Lloyd" <mlloyd@5xxxmail.com5xxx> wrote in message
news:u5lko0l5389vgi49622k01sig1ufse9jdn@4ax.com...
>>Thanks
> Mark Lloyd
Reply to user
> ...." screen when turn on but it doesn't do anything after that, I can't
> use remote or even turn it off with the power button. Is it bad sign?
> this unit works before .......
Have you rebooted it? Hold the power button down.
- Mark
Reply to Anonymous
- 0 +
I was able to get the system up after swapped out with another 160gb hard
drive. Now I can only record 1 show and it won't record another drive
because it's full. I just need to figure out what went wrong when I image
the drive, wish there is a way to tell how much space you have in that
system.
Thanks
"markjen" <mark.jennings4@comcast.net> wrote in message
news:07ljd.2492$V41.1362@attbi_s52...
> - Mark
Reply to user
- 0 +
>because it's full.
Did you patch the drive after loading the image?
JGM
Reply to JGM
>system.
>Thanks
Sounds like it thinks it has a very low capacity.
When you connect that drive to a computer, does RTVPatch show the
correct size?
Are you sure you used the "patch target drive" command right?
>> - Mark
Mark Lloyd
has a Replay 5xxx
"It is a curious thing that every creed promises a
paradise which will be absolutely uninhabitable for
anyone of civilized taste." -- Evelyn Waugh
Reply to Anonymous
- 0 +
I did the Restore Target Drive with new hard drive after find out my old
hard drive crashed.
I guess I need to patch instead, what is the correct procedure with new hard
drive anyway, I have a new 160gb
Thanks
news:91evo0t1332la2gc3e7650hck6r4ac2v4q@4ax.com...
>>system.
>>Thanks
> correct size?
>>>> can't
>>> - Mark
> Mark Lloyd
> has a Replay 5xxx
Reply to user
>hard drive crashed.
You wouldn't use 'patch' instead of 'restore' (WHAT are you
patching?), but AFTER 'restore'.
>Thanks
>>>system.
>>>Thanks
>> correct size?
>>>>> can't
>>>> - Mark
>> Mark Lloyd
>> has a Replay 5xxx
45 days until the winter solstice celebration
Mark Lloyd
has a Replay 5xxx
http://go.to/notstupid
Reply to Anonymous
- 0 +
Where can I find good reading for RTVPatch, I restored Showstopper & Replay
30 image 3.02 onto a 160gb hard drive but it seems lacking space and only
allows to record 1 show after that the drive is full, someone suggested to
patch to make it recognize big hard drive. Am I doing it wrong?
Thanks
news:f4i4p09r6q14qh253v0fmt7opival6fa21@4ax.com...
> >hard drive crashed.
hard
> >Thanks
hard
> >>>system.
> >>>Thanks
> >> correct size?
Moments
> >>>>> can't
sign?
> >>>> - Mark
> >> Mark Lloyd
> >> has a Replay 5xxx
> Mark Lloyd
> has a Replay 5xxx
Reply to user
On Wed, 10 Nov 2004 18:29:42 -0600, "\(Magic9\)" <noone@home.net>
>Thanks
http://rtvpatch.sourceforge.net/utility.html
>> >hard drive crashed.
>hard
>> >Thanks
>hard
>image
>> >>>system.
>> >>>Thanks
>> >> correct size?
>Moments
>> >>>>> can't
>sign?
>> >>>> - Mark
>> >> Mark Lloyd
>> >> has a Replay 5xxx
>> Mark Lloyd
>> has a Replay 5xxx
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
There are 732 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
