Sign-in / Sign-up
Sata hard drive, left power supply pin bend.
  • Hard Drives
  • SATA
  • Power Supplies
  • Storage
Last response: in Storage
December 27, 2011 3:30:52 PM
500gb hard drive sata.
I managed to bend the pin on the left of the power pins.
I'm using the hard drive in a sata swap bay, and now I cannot insert the hard drive
in the bay.
Now I can only use the hard drive, if I connect it directly to the power supply, and
make sure the left pin gets into the power supply connector.
Any ideas on how to get that left pin back on track?
Thanks.
More about : sata hard drive left power supply pin bend
a b ) Power supply
a c 227 G Storage
December 27, 2011 4:53:21 PM
Bend it back or replace the connector. Or buy a new drive for the bay and use this drive as is inside the case.
