Help connecting 2 pc's
Hi guys this is my question how can i connect a laptop and a desktop pc using a router .first the laptop is connected to the router wirelessly
the desktop is connected to the router via a cable plugged in the ethernet card plz tell me how can i connect them together
1 answer Last reply
More about help connecting
  1. Note down the names of the computers from Control Panel, System.
    Disable firewalls on both.
    Enable file sharing on relevant folders (right click in My Computer).
    Restart both.
    Go to My Network Places in My Computer select Add A Network Place, follow the networking wizard, making sure you supply exactly the right Computer Name(s).
    Also see Search, Computers or People.
    It's a slightly hit and miss business in XP in my experience and takes a little patience
    but in later versions of Windows probably simpler.
LAN Laptops Routers Connection Desktops Networking
