Hello,
Today i bought a new chassis cooling fan, i installed it to the case and the 3pin connector on the motherboard, after doing that the fan was running very very fast and it's making a "Bzzzzzzzz" noise, i took a look and i found out that the power supply fan was running very slow and it stops from time to time while the case fan is running very fast and making that noise, but now it's running just fine... it's not making any noise or anything, but everytime it makes the noise again...
What should i do ?
Is that normal ? Is it damaged ? Should i return it to the store ?
What should i do ?
