MadAdmiral said:
A budget would be nice, as would the intended resolution of the monitor. See the thread I linked to in my signature.
First, on the benchmarks, there are also ones where they test the CPU witht he same GPU. Check around this site for the actual specs. I don't believe the CPU will handicap the system much (if at all) since usually the most important part of a gaming system is the GPU. The reason they use the i7-920 for the benchmarking is because they can, and it is the least likely to have an problems in a game, as it is the most powerful CPU in mainstream use.
To start, nothing is technically "wrong" with the build, but it is subpar.
First, you're building on the older AM2+/AM2 board. For a little extra, you should be using the a true AM3 board (only states AM3). The older boards use DDR2, while the newer ones use DDR3.
So here are my recommendations:
Mobo:
ASUS M4A77TD. Cheap board, good if you don't want to add a second card later.
ASUS M4A79XTD EVO. More expensive, good if you do want to Crossfire.
RAM: 4 GB of 1333 mhz CAS Latency 7 (Timings 7-7-7-x). I would link to some G.Skill sticks, but they're hard to find outside of the US (which I'm assuming you are).
Case/PSU: It's alright, but might be a bit pricey. I'd look around. I know right now in the US, there's a great deal on the HAF 922 and an OCZ StealthXStream 700W (both of them for $100 after rebates). To compare, your deal is $110 for a slightly worse case and a smaller PSU.
GPU: I'd personally go with the HD 5770, especially if your resolution's less than 1900x1200.
To respond to your other suggestions:
The motherboard you suggested is the same price as the one i have chosen but then i need another type of memory (ddr3) and that one is atleast 40 euro's more expansive: Kingston ValueRAM KVR1333D3D4R9S/4G is the cheapest one i could find at 120 euro's versus 80 euro's i have found, so does it really make that much difference? May be i can buy the motherboard you suggested and put the ram at ddr2 that i found with it and will that work so i have not payed extra but if i want to upgrade my ram to ddr3 in the future it is possible or does it not work that way.
You said i am building on the older am2+ Am2 board but the board i have chosen Asus M4A78 PRO also supports am3, you also said that a true am3 board only states am3 so is the Asus M4A78 PRO not a true Am3 board and what are the disadvantages of that?
About the case/PSU: i have read many reviews about the psu build into the case and it said that it is very quite also the case looks not to futuristic like many other cases because it will have to stand in the living room therefore it has to look kind of bland, also the case is thick build keeps the noise down i have read many times. Your suggestion is not so cheap here in the netherlands the lowest price i found for both of them combined is 160 euro
Now that you know that i will have my monitor at 1900x1200 (or 1080) do you still think i should go for the 5770, i read that the 4890 is a bit more powerful but also takes a lot more power and heat therefore makes more noise. I like to be able to play every modern game at 30f fps or higher (higher then 30fps is not necessary) at 1900x1200 and highest settings (or most settings at highest) and full AA on or a little less AA. (modern games includes Crysis for me
). I hope i'm not aiming to high haha. Still 3dsMax is the most important thing because i'm studying to become a graphic artist.
Really appreciate the help
