Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > 800D or wait for Lian Li; Air Cooling
Forum CPU & Components : Power Supplies, Cases & Mods 800D or wait for Lian Li; Air Cooling
Ok so I have a 800D that I bought for $220 recently but I’m rethinking. I was looking at the Lian-Li PC-7FNWX which comes out on April 20. My concern with the 800D is that, I am going to air cool and I have heard it is not very well made for that. What’s your advice? Should I keep the 800D?
Message edited by nm324 on 03-14-2010 at 05:57:43 PM
Reply to nm324
Also, keep in mind, that I have bought a Venomous X with 2 Scythe Slipstreams.
Reply to nm324
The Lian-Li PC-7FNWX is an updated version of the 7FNW. The interior of the case appears to be similar to the Lian Li / Lancool Dragon Lords cases, especially the K62 model.
http://www.lancoolpc.com/en/produc [...] s_index=62
I just happene to have a Dragon Lord case. It is a mid-tower case that is definitely not as large as the Corsair Obsidian.
Reply to JohnnyLucky
Have you considered the CM ATCS 840?
Reply to blackjellognomes
Yes and I don’t like it...
Reply to nm324
Check out the Silverstone Fortress 02 this precise model.
SST-FT02B-W... It's black interior with a window. It's a pretty nice case.
It's like the Silverstone Raven 2 but with a more (exterior) elegant look to it and with a few modifications such as sound deafening padding everywhere feasibly possible. A hot swap bay, drive cages, sound padding etc. It uses a 90 degree motherboard mounting which means the I/o (or backports) of the computer are at the top of the case...
Message edited by AsAnAtheist on 03-16-2010 at 07:13:35 AM
Reply to AsAnAtheist
The reason I recommended the FT02 Silverstone case is because it is similar to the Lian-Li PC-7FNWX but has no front intake fan, and actually uses a stacked air effect. (Air is brought from bottom, exhausted at top.
The quality of the case is superb, cooling is superior to both, and keeps a very elegant look to it.
Between the Obsidian 800D and the Lian-Li PC-7FNWX I'd say choose whatever you feel more comfortable with. Both's cooling solutions are similar, with the Obsidian of course taking the lead. Both should not be considered for air cooling enthusiasts.
I will elaborate more on what JohnnyLucky mentioned:
* It is the same design as the Dragonlord k62 on the inside, the difference is there is no plastic bezels on the outside, it has a more polished surface look and does not have a full front panel ventilation. And finally the top ventilation plastic bezel was removed, and so where the ventilation holes for additional top mounted exhaust fans.
* Has limited cooling with only 3 fans. One front 140mm fan intake, one 120mm exhaust, and lastly the power supply fan which can or may not have an impact on the case depending on the side you face the power supply. (It can act as an exhaust which is not recommended, or act as nothing when facing down.
The Obsidian 800D is widely mod-friendly, however it's air cooling is limited but still superior to the Lian-Li PC-7FNWX. I would much rather keep the Obsidian 800D.
There are 1881 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 3 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
