Front audio panel
Last response: in Components
March 14, 2010 4:07:25 PM
hi...im using gigabyte MB e43...
i hv problem in plug in front audio to d MB...
my panel...
pin 1--mic2_l
pin 2--gnd
pin 3--mic2_r
pin4 --acz_det
pin 5--line2_r
pin 6--gnd
pin 7--faaudio_jd
pin 8--no pin
pin 9--line2_l
pin10--gnd
but my casing wire...
mic in
mic power
mic grd
ground
hpout-r
hpout-L
hpout r
hpout-L
plez help me.... :(
More about : front audio panel
a b ) Power supply
March 14, 2010 4:30:41 PM
look it up on google...
m
l
March 14, 2010 4:51:37 PM
still cant fine how to solve d problem...
m
l
a b ) Power supply
March 14, 2010 4:53:36 PM
eah i cant ehlp u because i have run into the same prob several times...theonly thing i could do was google front panel audio header pinout or somehitng like that...
m
l
March 14, 2010 4:57:14 PM
that y it very dificult...
wire writter in difrent signal than mobo instruction
m
l
a c 248 ) Power supply
March 14, 2010 6:04:45 PM
Check you motherboard owners manual and your pc case owners manual.
The manual for the motherboard should have a diagram that shows the location of the connections on the motherboard.
m
l
March 15, 2010 3:08:55 AM
manual MB and case manual difrent...
that very problem...
m
l
