I am replacing the stock fans in my HAF 932 adv case.
Here are the fans I am looking at
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233049
And the controller
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998096
Just looking for any advice, the horror stories for some of the controllers are kind of discouraging. Also I am only going to replace the top 230mm fan with 2 120mm, then i will replace the 230mm side fan with 4 120mm fans. Is this overkill?
I just put in a brand new Nvidia 690 and its temps have been fine once I replaced my MSI afterburner with the precision tool that came with it(looks like the same program with a different interface but I am guessing it is designed specifically for the 690 and the fan profiles are more customized) I have yet to O/C it though. Also have my 2500k running at a modest 4.3ghz o/c.
And the controller
