Sign-in / Sign-up
In Mac OS pen drive not detected how to find problem
  • Drivers
  • Mac Os
  • Mac OS X
Last response: in Mac Os X
July 12, 2010 1:25:46 PM
Hello,
hi, in my system i have mac os in that pen drive not detected . wt's the prblm
More about : mac pen drive detected find problem
July 12, 2010 6:48:06 PM
So you have Mac OS and own a pen drive that won't work when you plug it in?
Maybe try it in a PC - copy the files to the hardrive if it works and then format the pendrive on the mac.
I'd suggest going to disk utilities (search for it in finder). It should come up there, check to see if there's errors with it. If there is, or you're not sure it's probably best to format it. Just make sure there isn't anything on there you need. If you're only it in mac computers choose Mac OS Journ. Extended - if it needs to work on PCs too use Fat 32.
Good luck
m
l
July 19, 2010 10:47:02 AM
ya, have dual boot winxp and mac os, pendrive deteced pluded winxp its working ,but from mac os is not deteced
m
l
July 19, 2010 11:29:18 AM
different partition formats. you need to use disk management with the mac to reformat it.
m
l
