Hi. I am looking to build a new pc. I have replaced every item inside of a pc in my job but have never built a pc from scratch. I am trying to learn as much as possible on this website and through my job but am uncertain when it comes to matching components. Any and all advice is greatly appreciated.
APPROXIMATE PURCHASE DATE: this month
BUDGET RANGE: 950-1000 (would like to stay as close to this range as possible)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: a little gaming, MS office applications, internet, watching movies
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: New Egg
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: I really want to stick with the Intel i5 and an Asus mb. No preferences on the rest of the build.
OVERCLOCKING: Maybe SLI OR CROSSFIRE: No
I will be buying Windows 7 from the university I attend so I didn't add it in here. Also, do I need to buy thermal paste?
I think I can get $50 off with a combo on the PSU and case on New Egg.
Here is the list I have come up with. I would appreciate any help or advice you can give me even if it means I have to redo the whole list aside from the cpu. Thank you!
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
ASUS P7P55D LE LGA 1156 Intel P55 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131410
SAPPHIRE Vapor-X 100283VXL Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102868
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model F3-15000CL9D-4GBRH - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231280
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 48X CD-R 32X CD-RW 2MB Cache SATA DVD Burner with LightScribe LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118032
COOLER MASTER UCP RS700-AAAAA3 700W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS SILVER Certified Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171032
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case - Retail
