i have a ECS GF7050VT-M Motherboard and i cant quite run the games that i want with it.. can i upgrade it with this video card (Galaxy 95TGE8HUFEXX GeForce 9500 GT 1GB 128-bit GDDR2 PCI Express x16 HDCP Ready Video Card ) and run games like nba 2k10? or half life 2?
BTW i have 512 ram and
a intel pentium dual cpu @ 2.00GHz (E2180)
Specifications
Form Factor: microATX
Processor Interface: Socket 775
Processors Supported: Intel Pentium D
Intel Core 2 Duo, Intel Pentium Dual Core
Additional Technologies: HyperThreading Technology
RoHS Compliant
Vista Certified
Front Side Bus: 533MHz
800MHz
1066MHz
1333MHz
Northbridge: NVIDIA GeForce 7050/610i
Number of Slots: 2
Number of Pins: 240-Pin
Maximum Memory Supported: 8GB - 64bit
Memory Supported: 400MHz DDR2
533MHz DDR2
667MHz DDR2
800MHz DDR2 (OverClocking)
Single Channel Supported
Channels: 6 Channels
Audio Chipset: High Definition Audio (HDA)
IDT 92HD202
Video Chipset: Integrated VGA Engine in Chipset
Video Memory: 256MB Share Memory
Supported Devices: 2
Hard Drive Types: UDMA/133
UDMA/100
UDMA/66
USB Version: 2.0
USB Data Transfer Rates: 480Mbps
LAN Type: 10/100Mbps
Port Type: RJ-45
PCI Slots: 2
PCI Express X1 Slots: 1
PCI Express X16 Slots: 1
1 - PCIe (x8 Support)
PS/2 Keyboard Connectors: 1
PS/2 Mouse Connectors: 1
Serial Communication Ports: 1
USB Ports: 8
USB Rear Panel Ports: 4
USB Onboard Headers: 2 - (expandable to 4 USB ports)
LAN Ports: 1
Audio Out Jacks: 1
Line In Jacks: 1
Microphone Jacks: 1
CD-In Headers: 1
IDE Headers: 1
Serial ATA Headers: 4
ATX Power Connectors: 1 24-Pin Connector
PC Power Connectors: 1 - 4 Pin
Fan Connectors: 1 x CPU
1 x Chassis
VGA Ports: 1
Length: 9.606 in. (24.4cm)
Width: 9.606 in. (24.4 cm)
Specifications
RoHS Compliant
Vista Certified
800MHz
1066MHz
1333MHz
Number of Slots: 2
533MHz DDR2
667MHz DDR2
IDT 92HD202
UDMA/100
UDMA/66
USB Version: 2.0
Port Type: RJ-45
PCI Slots: 2
USB Ports: 8
LAN Ports: 1
Audio Out Jacks: 1
Line In Jacks: 1
Microphone Jacks: 1
CD-In Headers: 1
IDE Headers: 1
1 x Chassis
VGA Ports: 1
