Yes No
Ads
Tom's Hardware > Forum > Storage > CD/DVD Writers > DVD not reading writing ide problem?
Forum Storage : CD/DVD Writers DVD not reading writing ide problem?
Hi Guys
My sons sony cd/dvd writer is playing up on an Abit IL9 motherboard
Its recognised in device manager but refuses to read or write anything.
In device manager i have an exclamation mark in my scsi and raid controller tab which points to something called AVS5FS76 IDE controller that the driver is unable to be loaded for as its missing or corrupted.
tried uninstalling and on restart system pops up with found new hardware but fails to load drivers even though i downloaded the chipset drivers from Abit.
Can anyone help out or is this nothing to do with my Drive problem.
Thanks
Stanna
Reply to stanna
Looks like you have a bad IDE controller unless it is for some strange reason disabled in BIOS!
Reply to rolli59
- 0 +
So is that a hardware issue and if so what am i looking for.
Cheers for reply
Reply to stanna
- 0 +
Check your BIOS for disabled IDE controller and if none there is little you can do.
Reply to rolli59
- 0 +
Found this thread below and that has sorted out my ide controller
as i had daemon tools on my system.
Still my drive will not read orwrite disks but is mechanically ok?
http://www.tomshardware.co.uk/forum/247609-14-controller-missing-corrupt
"You guys may well have found this solution already but for anyone else who comes looking.
It's a hangover from daemon tools or another virtual drive program you've used.
find the driver in Windows/system32/drivers
(If you find a suspicious driver google it and see what it is)
Mine was sptd.sys (I'd been using daemon tools lite)
On another forum I heard the driver name might start with st3
Delete it (in my case I renamed and moved it to make sure it worked but didn't screw anything else up)
disable and uninstall the problem device in device manager.
It won't come back when you restart."
Reply to stanna
There are 1909 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
No Sata connection latch on SSD drive
By fantastik250, 18 hours ago:
I heard the sandisk ssd's don't have latches for some reason.
Best offers
Top experts
