Hello,
Like i don't get it. My temp core Idle when i don't overclock is 48C. But when i run OCCT at 100% loaded after overclock, it says that my temp goes at 92c and the test is stopped.
I read everywhere that overclocking the E8400 3.0ghz to 3.6 is super easy. This is the change that i do;
Set your CPU FSB Frequency to 400mhz
Now set your PCI Xpress Frequency to 100mhz
And i just cleaned my pc 2 days ago. I saved 10C Idle( that's a lot)
So what should i do? Because my pc run fine after i overclock to 3.6. Should i trust the test, change other setting or *** it the E8400 has fucked temp?
