f when you boot you don't have sound,there are 2 ways to fix it.
First(and not very effective) method:
Download drivers for your intergrated audio from the asus website.Install them,but when it prompts you to reboot,don't.You should have sound.(Keep in mind you mustn't have any open window at the time of the installation or you won't have sound).The bad thing with this method is that you have to do this every time you reboot.
Second(and permanent method)
Enter the BIOS and browse it until you find onboard devices.Open the submenu and change front panel type from hd audio to ac97.You should now,permanently,have sound.
Comment if it worked for you.
(I have posted this on win 7 drivers section too so that anyone can find it easily)
