No major issues during the process:
-I seated the CPU with care onto the pins on the board
-I was grounded well.
-I made sure no screws or standoffs were either overtightened or too loose.
-All power/data connections were triple checked.
The first time I powered on the system. I hear all the fans (cpu, gpu, and case fans) but nothing shows on monitor.
No BIOS, nothing, just black. When I open up the case. I can see the CPU_LED on my board solid red.
I did some research along with basic troubleshooting and went to sleep.
So today I open case again to make sure cooler wasn't too tight on cpu, even reseated GPU, RAM, etc...
The stuff I researched from last night....
When I powered again I got the same result. All fans and lights are on, but nothing to monitor just black and CPU_LED light is still solid red.
I'm thinking about RMA'ing the CPU.
Any troubleshooting left to do?
Will local shops test another CPU for FREE?
Help me out. If you need more info/details let me know.
Thanks.
[fixed]Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler - Retail
ASUS P7P55D EVO LGA 1156 Intel P55 ATX Intel Motherboard - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Retail
XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case - Retail
APEVIA CF12SL-UBL 120mm Blue LED Case Fan - Retail
APEVIA CF4SL-UBL-LED 80mm Blue LED Case Fan - Retail
Arctic Silver 5 Thermal Compound - OEM[/fixed]
Thanks.
