Solved
Alienware Cooling Unit
Hi there.
So I was thinking about upgrading my now aging 2008 Alienware Aurora (I think) and going through the list of things I might need. The q9450 processor is liquid cooled currently and is overclocked to 3GHz. I haven't had any problems with the processor AFAIK. Anyway that's not really why I'm here.
I just wanted to know what the deal is with the cooling unit. I cant really see what make or model it is. What is it and is it any good? How long will it last, considering I've had it for 4 years +/-? Is it easy to remove it, swap motherboards and processors and keep using it for the new hardware? It seems pretty big and sits in an awkward place in the case. Here is a picture of it
http://img825.imageshack.us/img825/1209/photo1iwe.th.jpg
Now that I think about it, my processor idles at about 41 degrees, is that high for a q9450 at 3GHz?
9 answers Last reply Best Answer
More about alienware cooling unit
  1. Best answer
    i doubt the cooler will fit on another motherboard, and it will not fit on anything but a LGA 775 (which is outdated at this point) motherboard for sure
    my Phenom II idles at around 40 as well, overclocked to 4GHz, so you should be alright
    I didn't even think logically that it obviously wouldn't work on a new motherboard lol. I am entranced by its mystery. I still would like to know who makes it and if it is any good and people's general opinions on it. Thank you.
  3. http://www.blogcdn.com/www.engadget.com/media/2008/04/4-15-08-aurora-alienware.jpg well im closer, a model number would help D:
    im sorry, i cannot find your PC anywhere lol
  4. amuffin said:
    i found that pic as well, we're you able to find any specs on it?
  5. Those cooling units are generally proprietary, though may be modified for use on another platform. New coolers are cheap enough that it's not worth the time or money to try and modify it, IMHO.
    Temps don't matter as long as your PC is running below the thermal ceiling (generally around 70-80C for CPUs), though it is an indicator of how well your system is cooling (i.e. if the loop is bad the CPU will heat up beyond the thermal ceiling). 41C sounds about right for one of these coolers on an OCed C2Q.
  6. Looks like a closed loop cooler facehugger.
  7. Hmm thanks for all the info. Yup that's the one in those pictures it looks like. I think I can see a barcode on the other side of the unit but I think I'd have to take it apart to even get to it and I don't know exactly whats written there... I cant's see anything other than the barcode. I tried using a mirror to get an angle but I can't see anything still lol. I can possibly give you more information on my computer but at this point I feel as though I've taken enough of your time so I guess I'll just live with the mystery lol. You have all been very helpful though so thanks again!
  8. Best answer selected by the_picard.
Water Cooling Cooling Processors Alienware Overclocking
