okay so i don't know what the heck happened but all of a sudden my computer is crapping out. my hard drive was getting full and slowing down my performance. i just went through and deleted files and uninstalled some programs. nothing was important or essential. just a few programs and install files that didn't need to be on my hard drive anymore because i didn't use them anymore or i didn't like them.
then xp popped up saying i had a couple updates to do. they were legitimate. i installed them restarted and then went to do disk cleanup and it wouldn't run no matter how many times i clicked on it. i restarted again and then my start menu is all screwed up
the my computer icon is named now folder. and i can click on it and it brings up my computer. i cannot click on any shortcut to run a program. i have to explore the program files and run the original exe file to get anything to load. i don't have the run, search, or help items in the start menu anymore. if i mouse over the all programs it doesn't bring anything up. i tried the start menu options and everything that should be displayed is checked but not showing up
i tried switching to classic start menu and i get the search and run icons and they will run. if i mouse over the programs it says i have no program files installed.
i have tried to use system restore and all it does is bring up a blank white menu window and i can't use it. task manager says its running but no options show up.
i have tried safe mode and same thing. same thing with safe mode with command prompt trying to pull it up that way.
i have never encountered a problem like this before so anything would be helpful. i have tried searching for a similar problem but nothing comes close enough to help me solve this. i also don't know where my xp cd is to try and repair or just reinstall xp
thanks
thanks
