Hello all.
I recently Crossfired (2) AT HD 5870's, and I installed MSI Afterburner to monitor temps and fan speeds.
On my HAF X case, I have two intake case fans, (bottom front and side), and three outtake case fans(top rear and top).
Since about three days ago, the day I changed settings and allowed MSI to take over and control the GPU fans, a weird thing possibly happened.
It appears like my two intake case fans are now blowing air OUTWARD, as if they have changed rotation! I can tell because there is no dust building up on the outer filters of both fans(which happens fairly quickly, pretty easy to see), as it usually will when fans are drawing air into a case.
Is it at ALL possible that installing Afterburner could have caused this? If so, how? I haven't taken out either of those case fans recently, so it's not a case of putting them in backwards. I always am careful to check the directional arrow and lable when putting fans back in.
If not Afterburner, what on earth could cause fan rotation to reverse? Power isuse? Windows setting? PSU problem?
???????? My head is abounding with conspiracy theories lol.
