Heating issue plzzzz help
Last response: in CPUs
i7 920 ati 5870 4gb ddr3 500gb HD
650w coolermaster
and a bad cabinet
on startign the game GTA 4. game played in medium due to heat
temperature CPU = 75-85 North Bridge = touchs 90+ ....south bridge = 75-80......motherboard = 55 max ...all in degrees
since i dont have alot of cash in hand i am going for a CM 690
Will it cure all the heat issues?? or should i do something else please advice need to get a cabient before it blows up
More about : heating issue plzzzz
A good ventilation is very important. I think that the temperature will decrease many degrees after that. To change the cabinet is a good idea.
Anyway, although the cabinet you choose is a good one, I would choose the Cooler Master 690 II Advance. It´s the new version of the 690.
Here you have a video review:
http://www.youtube.com/watch?v=Ed4RC6r2NTk
And if it´s not enough, you can change the heatsink for another better (Prolimatech megahalems or Noctua d14), but I think that you will get what you want with the new cabinet. The first step is that.
Related ressources
I'm running the Coolermaster RC690 and its doing a great job of keeping things cool. Hopefully it helps you out.
Having a broken intake fan makes a big difference- when you get the new case, might want to take the exhaust fan from your old case and add it to the new one (its got plenty of locations to add a fan:-)
Ask the community
