Win Power? Good/bad? Root of problem?
Ok, so after a nice quick reply to my previous thread, here's another!
Just checkout out my PSU, it's a WinPower brand, Max output 400W
If this is a really cheap PSU, could it be the problem with my GPU? I've got a Inno3D 8600GT 1GB card, can't find out anywhere what the minimum power supply is...
Any help much appreciated.
6 answers Last reply
More about power good root problem
  1. The card has a rated max power draw of 43 watts.
    Nvidia reccomended a 300 watt psu.
    Your psu gets a thumbs down for quality.
  2. Take a look at this.
    http://www.techarp.com/showarticle.aspx?artno=88&pgno=8
    It seems that your problem is not the power consumption of your graphic card because is very low and a generic 400w psu must be enough to move it.
  3. Thanks for both replies
    So, it's not the PSU, it's the GPU.
    But would you still recommend a change of PSU at some point? (delluser1's comment makes this likely!)
    I'm thinking of getting a GT240 for a replacement, and according to henry's (awesome) table, it'll use 125W, with the nvidia site recommending 300W PSU.
    I know the maths adds up, but just to get your opinion.
  4. The general rule of thumb is a high quality 500 to 550 watt power supply with sufficient current (amps) on the +12 volt rail(s) can easily power a system with any single video card made. A high quality 700 to 750 watt power supply with sufficient current (amps) on the +12 volt rail(s) can power a system with two video cards operating in dual mode. There are a few exceptions like the new ATI Radeon HD 5XXX series cards which use less power due to their energy efficiency.
    A high quality 500 to 550 watt psu will have a +12 volt rail rated at 40 amps. A high quality 700 to 750 watt psu will have a +12 volt rail rated at 60 amps.
    In addition the power supply should be at least 80+ Bronze certified for energy efficiency. There are some models available which have achieved 80+ Silver and 80+ Gold Certifications.
    Before purchasing a new psu you will need to decide whether you will eventually have a pc with one or two video cards.
    Corsair and Seasonic are two of the brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Some of the newer models come with a 7 year warranty. Lately we've been seeing a few other brands offering some high quality units.
  5. What about antec? Arent they quit good? I used to swear by them!?
  6. The newer models like the Earthwatts series and the Truepower New are very good. Some of the older series were not that good.
Power Supplies Power Components
