Hello:
I've got a Morex Venus 668 set up, and it's running pretty smoothly.
That said, if I end up trying to run something from the dvd drive (particularly if I run a large OS install), the power will spontaneously shut off.
To me, this means either one of two things:
1) There's not enough power being delivered, so it shuts down the board
2) Overheating and the BIOS shuts the PC down as a safety?
3) Bad memory issues?
Let me know if any of my assumptions are incorrect, and I'd appreciate if you'd let me know why too.
I imagine that my problem is actually #1, allowing it's viable. If so, are there any hard and fast rules on how to pick an appropriate PSU for a machine? I imagine I'd need to total up the draw from the components I'm using (MoBo, HDD, DVD, etc) and make sure my PSU is rated for said draw - is it just wattage I need to add up?
Also, is there a way I can find out what PSU's will work in my Morex Venus 668? I imagine there's a size requirement, yea?
I'd appreciate any help you can offer - I'm quite new to building PC's from scratch, and would appreciate the help.
-e-
-e-
