Thank so much to the input I've already had thus far from these forums. Kind of nervous to pull the trigger, but here's what I'm aiming for:
APPROXIMATE PURCHASE DATE: Next 12-24 hrs, BUDGET RANGE: Around $700.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: HD DVR/Media Center, capable of playing/rip Bluray (after future purchase of drive), stream hulu/orb, run XBMC & Miro, everyday internet surfing, productivity. No gaming.
PARTS NOT REQUIRED: No keyboard, mouse, monitor, speakers, already have PCI TV tuner, will get Win7 64-bit OS separately, outside this budget, from school.
PREFERRED WEBSITE(S) FOR PARTS: none specified, COUNTRY OF ORIGIN: USA
OVERCLOCKING: Not in the near future.
ADDITIONAL COMMENTS: Quiet is key, but powerful enough to smoothly function. Will go with onboard graphics unless I discover it's not enough, then will pick up an ATI card if needed. Going with modular PSU as they seem to work better in the 8000 case.
Current plan:
CASE – nMedia 8000 case. $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16811204039
CPU – AMD Athlon II X4 630 Propus 2.8GHz Socket AM3 95W Quad-Core. $113
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103704
MOTHERBOARD – MSI 790FX-GD70 AM3. $164
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130223&Tpk=MSI%20790FX-GD70
PSU – OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V Modular Power Supply. $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
TV-TUNER – Hauppauge card. (already have it)
HARD DRIVES – 2 x 1TB Western Digital Green Hard Drives (WD10EADS). $160 (already bought them, or else would have gone Samsung)
OPTICAL DRIVE – Samsung Super-WriteMaster SH-S223. $20 used (will switch out for Bluray drive later)
RAM – G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333, PC3 10666. $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
TOTAL: $722
Would really appreciate anyone who can let me know if they see any huge design flaws here or any reason this wouldn't come together for the purposes I described above. Thanks so much to everyone!
Current plan:
TOTAL: $722
