Cpu overheating even after cleaning pc and re-applying thermal paste
Recently my CPU (AMD Phenom II x6 1100t) has been overheating idleing at around 50C and maxing over 60 which is way to hot for this cpu. I first tried dusting out my computer which dropped the temps by 1-2 degrees but it was still overheating so i re-applied the thermal paste but ITS STILL OVERHEATING! My only other idea is that maybe it has something to do with my radiator but i dont know anything about it. Here's a picture of my cooler. Any ideas!?
http://imgur.com/WHvpIs
5 answers Last reply
More about overheating cleaning applying thermal paste
  1. Mate, its f*****. all you can do now is turn that *** ghetto and take a p*** on it every time it gets hot.
  2. I would look into purchasing another cooler for your setup. My Phenom II overclocked at idle is at 21C. Look into a good air cooler or buy another water cooler
  3. Any suggestions?, My motherboard is very small and i'm worried the ram will get in the way if i a buy a cooler that is too large.
    My Motherboard: http://www.amazon.co.uk/Asus-M4N68T-V2-Motherboard/dp/B004JJ050S/ref=sr_1_1?s=computers&ie=UTF8&qid=1345139521&sr=1-1
    Except mine is a slightly older version but i couldn't find it. But i presume its very similar.
    Thanks
  4. Try these, I am using Newegg.com from the US, you will have to find comparables in the UK:
    COOLER MASTER Hyper 212 Plus $29
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
  5. Thanks ill have a look at that one :)
Heatsinks Thermal Compound CPUs Overclocking Product
