I just installed a new CPU for my friend's computer (I've done this several times..not sure what I did wrong today) and after I turn it on and hit the power switch, it keeps beeping. (1 Long, 3 short) I googled it and it was a memory problem. We removed the ram, used the compressed air.
No go, so we removed the CPU, blew compressed air to make sure no dust.
No go.
It kept beeping.
We put back in the old CPU and it worked like a charm.
I upgraded
http://processorfinder.intel.com/details.aspx?sSpec=SLA8Y
to
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115206
I made sure the wattage was the same, everything was fine...
What should I do? Should I ask for a replacement incase its DOA? I have no way testing it though.
Note: I haven't tried resetting the CMOS..that may work?
No go.
It kept beeping.
I upgraded
to
