Hello everyone. This is my first watercooling loop and been reading lots on how to set this up. What I'm asking for is what you think and if there is something I've totally missed.
Case: Coolmaster HAF X
CPU: Intel Core i7-3820
MB: ASUS Rampage IV Extreme
Graphics Card: GTX690 Hydro or 2 GTX680 (still undecided)
Reservoir: Alphacool Dual Repack Dual - Laing D5
Pumps: 2x VPP655 (Laing D5)
Radiator: Swiftech MCRX20-QP 360mm
CPU Block: Koolance CPU-370
GPU Block: Attached on EVGA GTX690 Hydro
Fans for radiator: 3x Sythe Gentle Typhoon 120mm
The loop will look like this Pump1 + Pump2 into Y connector -> Res -> CPU -> GPU -> In on 1 pump other closed off. The Alphacool is a single res with 2 pump attachments. The radiator will be mounted inside the top of the case. Thank you and any help would be greatly appreciated.
