Hello,
I didn't know exactly where to post this but I have a problem and I think it involves the CPU.
My specs are:
PSU: FSP 500W
CPU: C2D e6300
GFX: MSI 7300GS
MOBO: MSI P965 Neo
RAM: 2x512 Kingston DDR2
HDD: 1x60gb IDE 1x250gb SATAII
Basically the computer was working the night before. I opened it up this morning and I see no display on the screen. The monitor is on stand by mode even though the pc is on. I thought at first it was the monitor but then I connected it to my laptop and it worked and I checked the cable and it was all fine.
I've just done an isolation test where I took out all the parts and put them back in 1 by 1 to see if it would make a difference.
Usually when I start up the pc it turns off instantly when I press the power button, but when I take the CPU out I have to hold the button for 5 seconds. I'm mentioning this because I don't know if it could help or not. When my PC functions as it is supposed to, I can only turn the PC off instantly at the boot screens when I press the power button. When it comes to the Windows XP loading screen you can't just turn it off unless you hold the power for 5 seconds.
Now I'm stuck on what to do. If the computer was shutting down after a couple of seconds I'd say it is the PSU. Or can the PSU still affect the display not showing anything?
I'm really out of ideas because I'm stuck with the CPU, the Motherboard, or the PSU.
Can anyone help?
My specs are:
PSU: FSP 500W
CPU: C2D e6300
GFX: MSI 7300GS
MOBO: MSI P965 Neo
Can anyone help?
