Hey guys, I've heard you are the best there can be. I was wondering if you all could help me Make a good set up? I'd like the best parts. BUT NOT OVER 300$ here's the current config I would like to get. Any mods for it?
What about These parts?
http://www.performance-pcs.com/catalog/i...s_id=32580 -Reservoir, Pump, and Radiator
http://www.performance-pcs.com/catalog/i...ts_id=1953 -Tubing
http://www.performance-pcs.com/catalog/i...s_id=34785 -Clamps
http://www.performance-pcs.com/catalog/i...s_id=22843 -Sleeve
http://www.performance-pcs.com/catalog/i...s_id=23512 -Fittings
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=21406 -liquid
Am I missing something? Are these parts compatible? This is the GPU block I wish to add
http://www.dangerden.com/store/dd-gtx590.html#tabs Please go over these and tell me if they are all compatable, I can't find the info for the fittings on the GPU block, and I have never done this before. Can anyone help me?
