I want to overclock my CPU to 3.0GHz from 2.70GHz so can you help me out? Actually I'm new to this thing so I want to know exact values that I have to change...(I am using the stock cooler but I want to overclock because if it will not get stable I can always revert later)
P.S.: I'm using a DDR3 1333MHz ram but as my CPU bus is 800MHz it's also run in 800MHz so does overclocking help with that? If so I want my ram to work in 1066MHz
[/URL][/img]
[/URL][/img]
[/URL][/img]
My mobo manual> http://files.sotmarket.ru/instr/komplektuushie_pc/motherboard/foxconn/mat_plata_foxconn_g41md.pdf
