Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Asus > Problems with >16GB RAM in P6T SE
Forum Motherboards & Memory : Asus Problems with >16GB RAM in P6T SE
System runs OK with 4 x KVR1066DN3N7/4G (on the compatibility list for the mb) installed but when I add the final pair performance slows dramatically and CPU usage increases significantly (to the point where even small tasks require 98% CPU usage and the system is practically unusable).
I have tried swapping around bays / slots / chips with same success / failure results. Also tried with 2 x 2GB chips in final 2 slots - same result. But with all slots filled with 2GB 1.6v Corsair 1600 chips everything works fine.
Tried clean boot - no conflict identified, didn't fix problem. Tried increasing DRAM bus voltage to 1.58 - made no difference. Is there a tested bios setting for 6 x KVR1066DN3N7/4G with my processor/MB that is known to work? My PSU is 1000w - so there should be enough power.
Spec:
*Product Model : P6T SE
*Motherboard BIOS Revision : 0808 (set to defaults - which according to Kingston should work)
*CPU Type : I7 920
*CPU Speed : 2.67
*Memory Vendor : KINGSTON
*Memory Model : KVR1066D3N7/4G (all tested with memtest - zero faults)
*Memory Used : 24GB (X6)
*Operating System : Windows 7 64bit
Any suggestions or even theories greatly appreciated.
Cheers,
David
Reply to DGoz
Have you tried down clocking your memory to a rated speed like 1066 or 1333. I have heard some people having problems with overclocking the memory when all six slots are filled.
Reply to adaman2576
- 0 +
Hi Adaman,
Downclocking didn't help - just seems the memory won't work in the final two slots. I ended up solving the problem by switching to the Asrock supercomputer x58 mobo in which everything worked perfectly out of the box.
Lessons learnt - Kingston support were really helpful with lots of specific suggestions - Asus support took their time and pretty much said I was on my own (not even prepared to suggest memory which they guaranteed to work!)
D.
Reply to DGoz
Well I'm glad you solved the problem. I hope I don't run into any problems with my asus motherboard after hearing about their crappy customer service. Maybe when I was trying to decide between the Asrock x58 and the asus p6t v2, I should of gone with the Asrock:)
Reply to adaman2576
increases significantly (to the point where even small tasks require 98% CPU usage and the system is practically unusable). gucciincreases significantly (to the point where even small tasks require 98% CPU usage and the system is practically unusable).
louis vuitton handbagsincreases significantly (to the point where even small tasks require 98% CPU usage and the system is practically unusable).
louis vuittonincreases significantly (to the point where even small tasks require 98% CPU usage and the system is practically unusable).
Reply to futurejelly
There are 1932 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Do I need a new motherboard?
By smorizio, 3 hours ago:
you waste your money unless you where getting an overclock cpu. any new mb with the same...
Best offers
Top experts
