Solved
Which sound card is better?
Last response: in Components
hey i need some help here
i don't know anything about sound cards and i really like amazing, crisp life-like game audio and music and found the Asus Xonar Essence STX its 199 dollars and has gotten good reviews
but the sound card from the Asus maximus formula 3 (sound is NOT BUILT in the mobo) looks promising but idk should i take the mobo sound card, get the essence instead or you guys suggest some other sound card?
More about : sound card
Your link is broken.
If you're ordering the motherboard anyway, try the sound card that comes with it first. Motherboard sound has gotten very good, and if Asus is already improving on it in the bundle... should be good enough for almost everyone. If you're still unsatisfied, you can find another product.
If you are gonna spend $200 on a sound card, you better have a hell of a good sound setup or good headphones. Otherwise it would be like guys with Honda Civics filling up on 104 octane gas.
Related ressources
Ask the community
