Hello! well i'm on the last leg of building my system, already ordered my case and accessories, heres my build..
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=15164786
...using mainly for gaming, my original budget was $1000 but i figured hey, why not, it's been a while since I had a great system so I guess this is what I'm getting now, pulling the trigger this friday. Anyways, I am really torn on my mobo. Toms recommended the Gigabyte and I have heard nothing but great things, but the P6X58D-E seems like a better chance to not get...well...a doa mobo or one with funny noise issues if you know what i mean. And then for the same price i saw the Rampage III Gene getting great reviews....
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
ASUS Rampage III Gene LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131658
So money being no object between these three boards, which do you recommend more for convenience, stability, and overall quality?
Also, I will probably OC a little, but i dont think any of these boards will be a problem.
