Hello all! I am looking to build a computer in the $1200 price range. I don’t need anything top of the line but I would like something I can game with right now and that I can upgrade within 1-2 years to be able to play the newer games.
APPROXIMATE PURCHASE DATE: In the next couple weeks
BUDGET RANGE: $1200. The current build that is listed below is around $1100. I could be convinced to go more or less depending on the reason.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, gaming, and gaming. Watching movies, surfing the net…
PARTS NOT REQUIRED: Case, keyboard, mouse, monitor, windows 7
PREFERRED WEBSITE(S) FOR PARTS: New egg… If you know of cheaper, I’m all ears.
PARTS PREFERENCES: This is what I have so far. Let me know what you guys think and let me know if I can improve anything.
CPU
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
Motherboard
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
Memory
G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8T-6GBRM - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304
Video Card
SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
Hard Drive
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Power Supply
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
CPU Fan
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
DVD-ROM drive
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD-ROM 48X CD-ROM 2MB Cache SATA DVD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151187
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
(Might do both down the road if needed)
MONITOR RESOLUTION: 1680 x 1050
ADDITIONAL COMMENTS: Thank to all of you in advance!
CPU
Motherboard
Memory
Video Card
Hard Drive
Power Supply
CPU Fan
DVD-ROM drive
OVERCLOCKING: Maybe
