Running a three monitor display on xp 64bit
  • Radeon
  • Windows XP
  • Graphics Cards
  • Monitors
  • Graphics
  • Product
  • Displays
January 8, 2010 11:28:23 AM
I just purchased a HD 5850 video card with the displayport and eyefinity technology. My question is will I be able to do the three monitor display running xp 64bit?
More about : running monitor display 64bit
a b U Graphics card
January 8, 2010 2:37:08 PM
Yes you should be able to.
Note: in order to have all your monitors connected to the card you need to have at least 1 monitor that has a display port connection. If you don't you will need to buy an active display port adapter, seeing as only the DVI connections+the display port connection can be used for Eyefinity with 3 monitors.
m
l
January 8, 2010 6:57:08 PM
Okay, thanks for the response. Now I have one more question, I do have a displayport adapter but it's a displayport to hdmi adapter, should I still be able to have the three monitor display?
m
l
a b U Graphics card
a b C Monitor
January 9, 2010 6:14:42 PM
That startech adapter will not work as it is a passive one.
m
l
January 9, 2010 6:23:13 PM
Okay Pfox, I'll go ahead and purchase the dual-link adapter. Thank you for confirming this with me.
m
l
