I recently changed from a small form factor case (Silverstone SUGO SG02) to a NZXT Source 210 and am curious about the optimal air flow for my components in their new home.
Here is a picture of how the case is setup, please note this is how it is normally orientated, on its side. I have it setup so air flows left to right.
Here is the environment it is in, on a soild flat glass surface just above the floor.
The fans I have installed are as follows:
Left intake - NZXT 120mm 1200RPM (Came with case)
Front intake - 2x Cooler Master R4-S2S-124K-GP 1200 RPM
Right exhaust - 2x Cooler Master R4-S2S-124K-GP 1200 RPM
Heatsink - 2x Cooler Master R4-L2R-20AG-R2 2000 RPM in push pull configuration
Is this an optimal setup air flow wise?
Would it be better to take out the right exhaust next to the heatsink so that a 2000 RPM fan is not blowing in to a slower 1200 RPM fan?
Should I take the 2000 RPM fans off of the heatsink and use those as exhausts and the 1200 RPM ones for the heatsink?
Should I remove any of the fans and leave just the vents? Remove fans and block some vents?
My hottest core idles at 37c and after 1 hour of Prime95 blend my hottest core gets to 63c. I don't think they sound extremely impressive, but are they bad?
I am using Dynex Silver thermal paste (was in a pinch and it was all I could get a while back), would it be worth it to get some Arctic Silver 5 or MX-2?
I have two fan locations left I can populate, or move fans to, if it would be beneficial, I have noted them with the yellow stars. One is on the back of the case and the other would be on the top of the case above the graphics card (side if the case was upright).
Any suggestions or opinions are appreciated.
