Hi, I've been doing tons of research on watercooling and I have almost everything I need now. However I just can't seem to understand tube and compression sizes. To my current knowledge I only know that I want G1/4 fittings and that describes the screw part of the barb/compression.
So I want to ask you guys what size compressions should i get? And when I know that, what size tubing to go with said compression? I just cant figure it out.
My build in progress:
Bitspower Water Tank Z-Multi 250 - 60mm
XSPC RX360 Triple 120mm Radiator
Swiftech MCP355 / Laing DDC 3.x Inline 12v DC Pump
XSPC RayStorm CPU WaterBlock for Intel Sockets
2x GTX 580 Hydrocopper 2 Waterblocks
Also, I'm debating whether I need the extra single rad in there. The RX360 is really thick. I don't know, maybe I'll add a single 120 rad also. Thoughts?
Another question as well. Does a bigger reservoir affect flow at all? Is a smaller one better?
