So i picked up the Mushkin last night cause the rebate was going to end and i kind of bought it on a whim. Thanks to Tecmo who helped me decide!
I thought I'd ask if there is a noticeable difference between these two for gaming and which one would be better, to provide better FPS, i know its not much but i've seen on benchmarks a difference of 6-10 FPS at times depending on the RAM. Does anyone have any good reviews or benchmarks on these two RAMS?
The newer Mushkin is at 6-8-6-24 while the Trident is at 9-9-9-24, but i've read more reviews on the trident (maybe their marketing is better).
Trying to decide today if i should just keep the Mushkin or return it and pick up the Trident. I will be running this on...
eVGA X58 SLI Mobo
i7 930
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226121&cm_re=Mushkin_Redline_6gb-_-20-226-121-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231254&cm_re=G.Skill_trident-_-20-231-254-_-Product
I picked the Mushkin up with a 30 dollar Mail in rebate, so the price was around 159 instead of 189 today.
Cheers,
Jack
eVGA X58 SLI Mobo
i7 930
Cheers,
Jack
