Setting up tv as monitor
Hello,
i was told by brighthouse didnt nrrd any adpters just go my computer and split devises do not see that
3 answers Last reply
More about setting monitor
  1. First, be more clear and detailed. Next, run spell check and put some effort into your post.
    What inputs are on the TV? HDMI, VGA, DVI, etc?
    If your computer has DVI and the TV has HDMI, then just get this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16812270116
  2. I found I have the least Issues with VGA inputs (aka the regular D-sub 9 pin blue plugs) otherwise if you TV doesn't have one. Otherwise yeah, DVI to HDMI.
    Getting audio to work correctly might require help...
    Post what your TV models is and your computer's model / video card...
    lol
    http://www.speedtest.net/result/756218868.png
CPUs TV Computer Monitors Product
