I've just installed a custom water cooling loop in my rig and the temperatures seem just a bit to high! Here are the specs of my system then water cooling rig. Why the feck are they soo high?
CPU- 2600k Stock
GPU- Asus GTX 590
Storage-120gb ssd
Case- Haf 932
MObO- Asus Maximus Extreme 4 rev 3.0
Reservoir/pump=Koolance d985
Tubing - orange 1/2 ID 3/4 OD UV
Fittings - enzo tech compression fittings on Pump CPU and GPU
Fittings- Barbs on Radiators and outlet for Pump
3 bitfenix pro fans for the 360mm radiator on top 30 FPI
1 bit fenix spectre pro fan for 120mm Radiator
Danger Den gtx 590 GPU block
Aquacomputer Cuplex Kryos Acetal
Koolance high performance cooling liquid- No color
Artic MX4 thermal paste on GPU cores and CPU core.
Room temp is 28 C
Cooling temp is
CPU -50-80 C
GPU- 40-70 C
Pump is on full speed and I've bleed the system of air.
CPU- 2600k Stock
GPU- Asus GTX 590
Storage-120gb ssd
Case- Haf 932
Room temp is 28 C
Cooling temp is
CPU -50-80 C
GPU- 40-70 C
