So I just got the antec tri cool 120 side fan for my case and had a few questions about installing it.
I'm installing it on an Antec 1200 with an EVGA x58 SLI mobo.
1. Where do you put the 3 speed fan control switch that is attached and dangles from it?
2. Is there a program that can control the fan's speed? If so what speed should the 3 speed fan control be left on to when using the mobo to control the speed?
3. What should be set in the bios "PC Health" section for this fan to work properly and be controled properly?
Thanks for any input
