I'm building my first computer and it looks like I have everything set to go, but it won't power up. The PSU's fan turns on when I use the "paperclip trick", so it's not that. The only thing I can think of is that either the mobo was doa, or because I can't find out where to put a plug that came with my switch that is labeled "Power SW" at the end. It has two square inserts at the end . I can't find where to plug them into on the mobo. Is there a specific spot? And would not having this plugged in effect the motherboard getting power from the PSU(the PSU has a master on/off switch)
