Solved
Will Noctua NH-D14 Fit In My NZXT Lexa S Case?
Rig is in my Sig!
Right now i'm running hyper 212 Evo with single fan in push config.
In the future I'm thinking of doing OC'ing on my 3570K to maybe 3.5-3.6 Ghz & I was thinking if the NH-D14 is a worthy upgrade to the cm hyper 212 evo or not?
Will the difference in temps be noticeable?
And more importantly will the NH-D14 fit in NZXT Lexa S? Will my RAM or GPU interfere?
6 answers Last reply Best Answer
More about will noctua nzxt lexa case
  1. Best answer
    It will fit!
    A Hyper 212 EVO is optimal all the way up to 4.2ghz, anything higher would require something like the NH-D14.
    Don't upgrade if you are only going to go 100mhz above stock clocks!
  2. amuffin said:
    http://i128.photobucket.com/albums/p186/pallac/PC/IMG_1878.jpg
    It will fit!
    Hey muffin, THANK YOU SO MUCH!!! :D :bounce:
  3. Best answer selected by WILDLEGHORN.
    It will fit!
    But will my RAMs or GPU interfere ?
    I have 2 sticks of 4GB RipjawsX 1600 CL9D (dual channel kit) & Zotac 670 Amp on the topmost PCI Express 3.0 Slot! Mine is an ATX mobo btw.
    Plz answer, thanks!
  5. amuffin said:
    no.
    Thanks I'm getting this cooler shortly :D
Heatsinks Cases Configuration Evo Overclocking
