r_manic :
What kind of problem? How does your computer say that you have a problem?
The audio simply does not perform. Control panel says 'it may not be configured correctly' Won't let me un-install, only disable. Have tried several cycles, but same result with Asus' latest driver.
I note several if not many have had the same problem with this board in this way.
I had no problem with the audio malfunction until I did a re-install of XP.
Seems to me to be a problem in the sequence in which the driver is installed relative to other drivers, maybe needing to be installed very early on.
One suggestion elsewhere was to disable soundcard/NB Azalia in the bios + a sequence but am reticent to do that without more knowledge.
