PURCHASE DATE: End of January/early February.
BUDGET RANGE: around $1000 or cheaper.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming mostly, dvd ripping, work.
PARTS NOT REQUIRED: monitor, mouse, keyboard.
PREFERRED WEBSITE(S) FOR PARTS: Newegg is usually the best, but whichever is cheapest.
COUNTRY OF ORIGIN: Cananda
PARTS PREFERENCES: whichever works
OVERCLOCKING: not sure. Still new at this.
SLI OR CROSSFIRE: SLI
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: First time building my own pc. Would enjoy imput on extra ideas and compatabilities.
Case - RAIDMAX SMILODON ATX-612WBP Black 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case With 500W Power Supply - $89.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811156062
CPU - AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor- $174.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103674
Mobo - ASUS M4N82 Deluxe AM3/AM2+/AM2 NVIDIA nForce 980a SLI AMD Motherboard - $169.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131383
PSU - Rosewill Xtreme Series RX750-S-B 750W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready CrossFire Ready, Active PFC "Compatible with Core i7, i5" Power Supply - $91.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817182067
RAM - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ- $88.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231122
HDD -Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - $79.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148395
Optical - LITE-ON Black 24X DVD+R 24X DVD-R SATA Black 24X DVD Writer LightScribe Support - $31.99
http://www.newegg.com/Product/Prod [...] 6827106335
Video Card - GIGABYTE GV-N26OC-896I GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - $195.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125291
Alright that's about it for now. I' still learning so any suggestions would be greatly appreciated! I'm going to use windows 7 home as my OS. I would also like to know if I would need a CPU cooler.
Total is a little higher than $900.00 before shipping, and taxes.
