Sign-in / Sign-up
Solved
HD 6450, power usage?
  • Graphics Cards
  • HD
  • Memory
  • Overclocking
August 30, 2012 1:38:34 AM
Hey I've overclocked my Sapphire HD 6450 as I want to play mass effect 3 on my old computer and I wanted to know if my PSU can handle the extra wattage.
My stock settings are
Core 625mhz
Memory 667mhz
Voltage .975v
The settings I am running are
Core 750mhz
Memory 800mhz
Voltage .980v (it seemed a little stabler with the small voltage increase)
I highly doubt this is a viable source of data but a CPU oc calculator says 23watts over the original 18watts. (which is probably more or less the increase In wattage I'm getting anyway, "the reference card has the memory at 800mhz anyway" which is rated at 18 watt
My PSU is an OEM 250watt which is 5 years old
I highly doubt I have much to worry about with such a lower wattage card anyway... but I'd rather ask
The card is a low profile passive cooled card with an added fan (I had overheating problems, not a problem now "30-50c vs 60-90c")
Thanks
More about : 6450 power usage
a b K Overclocking
a b } Memory
August 30, 2012 2:22:03 AM
Need more info on your setup, but 23 watts isn't much of a load on the PSU...Although, if the PSU is rated at 250 watts it is pushing around 175 watts if it is 70% efficient...So you do not have as much headroom as you thought....Like I said if you provide more info on the setup it would help
m
l
August 31, 2012 8:38:02 AM
Intel Core 2 Duo E6700, 2.66ghz 4mb cache
Sapphire HD 6450 1GB DDR3 (upgraded from an HD 2400 pro)
3GB DDR2 @ 333mhz (667)
The Motherboard is from an Acer SA-90 (it used a 3rd party chipset)
250GB HDD
m
l
Best solution
a b K Overclocking
a b } Memory
August 31, 2012 2:41:33 PM
Yep, you will be fine with that PSU...
September 1, 2012 6:12:48 PM
Best answer selected by mikes1992.
m
l
