Solved
CrossfireX interconnect cable for HIS H467QR1GH Radeon HD 4670 1GB
I bought an AMD Crossfire X compatable Motherboard and i found the duel graphics cards i want to run on my system, http://www.newegg.com/Product/Product.aspx?Item=N82E168..., but i'm looking at the pictures and it doesnt look like it has the standard internal card-to-card connection port. I thought i saw earlier today an external DVI interconnect cable but i cant find it now. The major product sites dont tell me what interconnect cable is needed, if someone could help me, i'd appreciate it.
thanks in advance.
Best solution
Graphics card Master
That card does not need an interconnect cable. It will use the system bus to initialize crossfire. The DVi dongle was the very first way to connect 2 ATI cards in crossfire back in the x1800/x1900 days.
May I add, you mentioned the (2) cards you want to get. I am assuming you do not currently have them. Unless you are running 4 displays, I would suggest getting the 5770 for the same price as (2) 4670 cards. http://www.newegg.com/Product/Product.aspx?Item=N82E168... OR even a 5750 for a lower price if you do not need the performance. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Ask the community
