Help Finding Battlefield 3 Patch On system
Hey guys, i need to reinstal windows, and have Battlefield 3 installed with the HUGE 3.9 GIG patch, Just wondoering if anybody knows where i could find it to put it on disk to saveme the download? I assume itd have to be the EXE?
Thanks Paul
Hey guys, i have found the PATCH folder... but cant seem to find an EXE? Does this mean id be unable to use it on a new system?
2 answers Last reply
More about help finding battlefield patch system
  1. It may not be stored once applied... You may want to download it directly so you can apply it once you finish the reinstall.
    IV FOUND A FOLDER WITHIN THE BATTLEFIELD 3 FOLDER NAME update WHICH IS 3.81 gig, which is about the right size, problem is there no EXE its just files, im just putting it on disk now and ill put it in the folder when i re-instal it and see if the game recognizes it. doubt it but worth a try for a 3.9 gig fiile lol
Download Battlefield Storage
