Hey ppl from tomshardware, im currently having a problem with my fx-8150, it downclock itself down to 1.3-1.4 ghz while idle and that is fine but whenever I am playing a more demanding game ( Ghost Recon, Battlefield 3, WoW, Dead Space 2 )
it will randomly downclock itself to 1.3-1.4 ghz while in-game and cause little lag spikes.
It also goes down to 1.3-1.4 ghz when im ALT Tabbing out of a game and then it will take several seconds ( 7-8 ) before the game re-opens back up after clicking on it because the CPU speed stays at 1.3-1.4 ghz until the game is up again. I am looking at the core speed on CPU-Z
Also there is an older game( can be played on single core ) I play that makes my CPU stay in turbo boost( it will go from 3.9 to 4.6 ghz and the stock core is 3.6) all the time and reach high temps(55-60 celcius)
What can I do to fix this?
Specs :
AMD FX-8150
ASUS Sabertooth 990FX
ASUS GeForce GTX 550 TI
Corsair Vengeance 16GB @ 1600MHZ
Corsair 650TX PSU
1TB 7200RPM HDD
About the cooling, I am using a Zalman Z11 PLUS case and it keeps the temperatures within what it should be. It is not a cooling problem.
I have tried many things such as disabling power saving options in the bios and it just won't run 3.6ghz when needed and if anything, it just won't run 3.6ghz at all. Its either 1.3-1.4 or max turbo boost while not necessary.
Any suggestions?
Specs :
AMD FX-8150
Corsair 650TX PSU
1TB 7200RPM HDD
Any suggestions?
