Please help, getaway fx or homebuild and what do i do? i need help
thanks in advance, i have never put a complete pc togheter from scratch, i have changed parts here and there, and i wanted to try and put one together, here is what i had in mind
http://secure1.ncix.com/cart/
also for now an 8800gt until i have enough for a 5850
now, once i plug everything in on the motherboard and then i put all in the case, what do i do?
1 turn pc on
2 ?? does everythig set itself up automatically?
3 is there anything i should do before installi win 7?
thanks so much
also, if i chicken out, i could get a new getaway fx for cheap, its an i7 920, 16 gb dd3, 1 tb hard drive, 750 power supply, 5850 ati, it would almost cost me the same, the only thing is i dont know about gateway, are they good? reliable? or is it safer to build my own?
please advise me well
thanks in advance
4 answers Last reply
More about please help getaway homebuild help
  1. Your link does not show me anything. You will get better response if you list your parts in the post.
    You might try things outside of the case first; conect the cpu, it's cooler, ram, the monitor, and a dvd reader.
    If basic tests are OK, THEN install in the case and load your OS.
    You should get into the bios first and look at all of the settings which should be defaulted. You might want to set sata to AHCI which may not be the default if you might ever want to use a trim supported SSD.
    I always run memtest 86+ from a cd or floppy first.
    Load the OS first.
    Then update with the motherboard chipset driver cd which comes with the motherboard.
    Apply all the OS updates.
    Then install security and your apps.
    Gateway may not give you a quality PSU which is important.
    They also make money by preloading lots of trialware/bloatware. You do not want that.
    16gb on a i7-920 is strange. It implies 4gb sticks which are very expensive. 6gb or 12gb using 2gb sticks is the norm. List the components here because something is fishy.
    Gateway/dell/hp are hard to beat on cheap/basic systems, but for a high end system you probably can do better yourself.
    Regardless, the experience and satisfaction of building it yourself is priceless.
    Regardless, you
  2. here is the one i would like to try and build
    Reference ID:1035489595
    Del Item Description In Stock Part # QTY Price Ext. Price
    OCZ Gold OCZ3G1600LV6GK 6GB DDR3 3X2GB DDR3-1600 PC3-12800 CL 8-8-8-24 Triple Channel Memory Kit
    Usually ships in 1-2 business days.
    In Stock 35710 $186.73 $186.73
    ASUS P6T SE X58 ATX LGA1366 DDR3 LGA1366 3PCI-E16 PCI-E1 2PCI CrossFire SATA2 Motherboard
    In Stock 38342 $269.99 $269.99
    Add NCIX EXTENDED SERVICE PLAN What's this?
    Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM
    In Stock 31000 $99.99 $99.99
    Intel Core i7 920 D0 Stepping Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 -SLBEJ-
    In Stock 38881 $339.92 $339.92
    Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan
    for the gateway fx, i triple checked the store, and it does come with 16 gb dd3 ram, 5850, i7 920, blue ray dvd and 1 tb hard drive, bluetooth and wifi as well and a 750 w power supply, they had one left and i put it on hold until friday... now i must decide, please guide me the rigth way!!!
    Extended service plans are usually a ripoff. The salesman gets a good comission selling them.
    I looked at the gateway web site, and do not see a 920 system with 16gb of ram, the most is 12gb. To get 16gb of ram, you need either a server motherboard, or a kit composed of 4 4gb sticks. 4gb sticks are very expensive . A kit of 16gb will cost $800 on newegg:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231309
    Even if 16gb was correct, 16gb is not evenly divisible by 3, so you would be running in no better than 2 channel mode. Not right, something is fishy.
    If you buy it, make certain that you get that 16gb in writing with the option to return.
    The list of parts you listed looks good.
  4. thank you, i think i will just go and build my own, hope all goes well, if not..now im a member here, i hope you people will help me out, should i encounter...problems
    thanks for your time
Homebuilt Systems Product
