APPROXIMATE PURCHASE DATE: Budget cost is sub $1500
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, movies, school
PARTS NOT REQUIRED: I already have a Monitor, keyboard, mouse.
PREFERRED WEBSITE(S) FOR PARTS: newegg, tiger
PARTS PREFERENCES: Intel!
OVERCLOCKING: Maybe SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1440x900 (max resolution atm on monitor, but may end up upgrading in future but not near future) Plan on getting another monitor in the future so duel setup.
ADDITIONAL COMMENTS: Will not over heat, that is a huge concern, it gets really hot where I live during summer. I may invest into another 5870 in future, or will that be overkill?
Also any routers that anyone can recommend, I have x2 computers and x2 consoles that NEED to be hardwired. But I also have two computers downstairs that will need to be wireless. Will also need to hook up my printer to the network too. Any help would be appreciated!
CPU = i7-920 Bloomfield
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202&cm_re=i7_920-_-19-115-202-_-Product
MOBO = EVGA 121-BL-E756-TR LGA 1366 Intel X58 Micro ATX SLI Micro Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188051
RAM = G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231306
HSF = Cooler Master Hyper 212
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
HDD = SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
PSU = CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
GPU = SAPPHIRE 100281SR Radeon HD 5870 (Cypress XT) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card w/ATI Eyefinity - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102856&cm_re=5870-_-14-102-856-_-Product
DVD = SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD-ROM 48X CD-ROM 2MB Cache SATA DVD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151187
CASE = Cooler Master HAF 922
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=haf_922-_-11-119-197-_-Product
Total roughly $1500
Total roughly $1500
