MATX, Portable Hardrive and Build review questions.
I have a few questions. Heres the situation: The computer will be left in one place and will only need to run 2-3 a week, all on the same date. It needs to be small, but it will be doing a lot. Too transfer files back and forth, whats a good USB drive (say 320gbs) Since the case i want has a eSata but my computer at home doesnt, it will need both.
Is this combo a good idea?
HD- http://www.newegg.com/Product/Product.aspx?Item=N82E16822145274
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16817810016
Entire Build (its always nice to have a second set of eyes look it over, also this is my first small build / MATX)
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811204035
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813135254
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103724
Ram - http://www.newegg.com/Product/Product.aspx?Item=N82E16820227248
Internal HD for OS - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148231
How good is the IGP on the mobo?
Thanks for the help.
2 answers Last reply
More about matx portable hardrive build review questions
  1. I think it would be better and cheap to go with this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822324025
    Am i wrong?
  2. Also, Do i Need a MATX PSU for my case or can i use an ATX? How can i tell (dimmensions?)
Power Supplies Cases Computer Build Components Product
